Reply
U.S. Cell phone service keeps dropping
Hi,
My brother is in the U.S. on a phone using PM. He bought the talk ans text roaming plan. Everytime he calls out, he gets connected and soon hear 3 beeps, and then the call drops after about 10-15 seconds. Repeatable problem.
Anyone know anything?
Thanks,
Mike
Re: U.S. Cell phone service keeps dropping
@halifmike
Does texting function work?
Maybe try rebooting phone.  Manually choose either T mobile or AT&T, then vice versa.  Enable roaming on phone.
Your brother could try to manually select either T-Mobile or AT&T network.  Also try rebooting phone.
Thanks, Dunkman, for the very rapid response!
I'll tell him to check that he is connected to one of those carriers. I assume he wouldn't be able to call out if roaming was not turned on.
I think he is not getting text messages.
I'll post here how it goes.
@halifmike wrote:
Hi,
Thanks,
Mike
Maybe he bought multiple same add-ons. Is he not able to post directly here rather than a thrid party?
Thanks. Already working on this same suggestion from Dunkman.
He DID buy multiple same add ons by mistake!
What can he do about that to fix it?
@z10user4 wrote:
@halifmike wrote:
Hi,
Thanks,
Mike
Your brother would need to submit a ticket to a moderator.
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:  https://www.publicmobile.ca/en/bc/get-help    -> Click on Chat with Simon - on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!
Thanks again, Dunkman. I had him make sure he was connected to T-Mobile or AT&T, and that he had is phone set to allow roaming. He re-booted and voice is still not working. But texting is.
Another poster suggested he might have muitple add-ons for U.S. Roaming. He does. He bought one ($8 voice only) then thought he had not, and I bought one for him ($15 voice and text). There are now three showing on his account.
I sent a message to the mods to see if they can remove the charge and the add-ons.
What do you mean about multiple same add on purchases? Are you implying that the add ons are interfering with the service? Is that possible?
@z10user4 wrote:
@halifmike wrote:
Hi,
Thanks,
Mike
