Travelling to U.S.
phustler7
If i purchase an add on for roaming in the u.s it says talk and text but doesnt specify if it is unlimitted talk and text. Is that unlimitted if i am in the u.s. if i get that add on?
MoreYummy
buy it whenever you want to use it,  it begins from the moment you activate it.
cavemantoronto
It is unlimited only while in u.s. if you have a limited plan for using in canada.
Lieux
Yes if it's not specific detailed...it's unlimited...talk and text!!! But it's only for 10 days be careful as soon as you buy it it's day 1...
