Travel to Southern Ireland
3Brooks
Can data and text be purchased for travel to southern Ireland?
jor123
@geopublic wrote:
@3Brooks  For data you just need to purchase a prepaid plan from a local provider.
And that'd probably be cheaper than roaming from any Canadian provider anyway.
hairbag1
If you're going to have access to wifi, consider getting a free voip app like TextNow. With a wifi signal you'll be able to send and recieve free calls and text messages. Works perdy decent too.
Alternative is to  procur a local sim card while in Ireland, as suggested already.
Good luck and safe travels.
geopublic
Public Mobile only offers service in Canada and roaming in the United States.
