Reply
Transferring number from Koodo
Hi! I need some help
I just activated my account on Public Mobile and I want to transfer my old Koodo number to use as my Public Mobile number. But I got this error message when I put in my old number and check it's eligibility.
Transfer.pngI have made sure that the number is correct. Any help is appreciated!
Thanks
Re: Transferring number from Koodo
Thanks
If Koodo prepaid then you will need moderator assistance.
Thanks
@Moderator_Team
Press their name scroll down to "contact me" and send a private message detailing you number, former provider, former plan type (prepaid, etc.) And any other information you feel may help them correct this. The more details you give the less time it takes for them to take action
Alright, I'll try to private message the moderator
I forgot to add, if your community account email and your PM account email do not match they will also need your PM account info.
Thanks for the info! I'm waiting for the moderator to reply
Hope they get back to you soon. If I had to guess the latest they would respond would be Monday.
 I suppose if that's true then I'll have to wait. Thanks for the help!
Your welcome, on the bright side your interaction with the community over this matter might save you a bit on your next phone bill Smiley Happy
Lots of Peep from PM moved Koodo
Koodo Peep moved to PM also Cat Happy
