04-25-2019 09:37 PM - edited 01-05-2022 04:36 AM
04-25-2019 09:41 PM
@Lola1614 Did your plan recently renew? There is a bug affecting a bunch of customers.
Try this:
1. login to your account >> Plan and Add-ons >> Lost/Stolen Phone >> click Suspend Service >> logout
2. login to your account >> Plan and Add-ons >> Lost/Stolen Phone >> click Resume Service >> logout
3. wait a few minutes, reboot your phone and check for service
If that fails click his: message to moderators to send a private message to the moderator team with a description of your issue. Usually they answer within in 24 hours, but can take a few days. Do not send multiple messages. This increases the queue and adds to the time moderators take to locate all your messages. Refer to the following knowledge base link for additional information on contacting the moderator team.
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Good luck.
