02-04-2020 02:07 PM - edited 01-05-2022 09:20 AM
I just checked my call log and it is showing calls made when I know they weren't.
The first one was this morning when I was sleeping and the second one was an hour ago and I know I did not make any calls.
It is not an issue as both calls were under a minute. I'm just wondering if anyone else has experienced this.
I checked my 100 mins if outgoing calls and it shows zero, so I'm very confused.
Any explanation for this ?
02-04-2020 03:13 PM
@Dolphin1 wrote:No worries I won't be contacting a mod. I think I understand why this is happening it just doesn't make sense to me.
@Dolphin1 Someone calls your number and for any reason you do not answer the call then PM's network will forward that call to voicemail (xxx-580-4001). So what you see in your usage log is that entry and because all incoming calls on your plan are free + forwarding to voicemail is free there is no charge.
02-04-2020 02:31 PM
What time zone are you in vs time zone that call detail is in?
02-04-2020 02:17 PM
02-04-2020 02:16 PM
02-04-2020 02:16 PM - edited 02-04-2020 02:18 PM
Because it's a forward, and forwards are outgoing calls
If the call is forwarded to voicemail it is not counted against your 100
If you call voicemail it is counted against your 100.
There system knows how to separate them (flag goes off somehow)
02-04-2020 02:15 PM
I understand it goes to voicemail but why is it logged as an outgoing call when I did not make a call ?
Isn't that an incoming call ? I pick up voicemail from a landline not my cellphone.
@popping wrote:
@Dolphin1 wrote:I just checked my call log and it is showing calls made when I know they weren't.
Is that call to a number with the loast 4 digit 4001?
If yes, it is your voice mail number. When you did not answer your incoming calls, they will be forwarded to your voicemail for your caller to leave a message for you.
02-04-2020 02:14 PM
@Dolphin1 wrote:There was a voicemail but how does that could as an outgoing call ? They called me I didn't call them.
What number is being called? Is it like xxx-580-4001?
It's possible someone tried calling you and the call ended up going to your voicemail.
That's just how it gets recorded on your log history.
02-04-2020 02:13 PM
02-04-2020 02:13 PM
Mine is lear. Do you know these numbers? Probably someone else has the same phone number as yours? Check with moderator: click the "?" in lower right side of the page, type "contact moderator", and follow directions. OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Sorry there is no reason to contact Moderators regarding this issue.
02-04-2020 02:13 PM - edited 02-04-2020 02:14 PM
It's probably forward to the voicemail which is free
Guess number end with 4001 or 4002?
Forwards to the voicemail are not counted against your 100 allowance, but calls to it are
02-04-2020 02:13 PM
02-04-2020 02:11 PM - edited 02-04-2020 02:12 PM
