Reply
Highlighted
Shareablity
Hi, Is the mobile data included in your 40-dollar plan sharable?
Accepted Solutions
Highlighted
Re: Shareablity
All Replies
Highlighted
Re: Shareablity
Highlighted
Re: Shareablity
@npakniyat  If by shareable you mean using a hotspot the answer is yes, otherwise it's no.
Highlighted
Re: Shareablity
There are no shared plans as it is pre-paid.  It is a bit inconvenient I would be happy if I coudl add two lines using the same log in email, I have two lines likely adding another for my third kid and I have to have then three log ins.
