Returned from US, data not working
mikeman123
Hi all. Just returned from the US where I was using a roaming data add on that worked great. However since I've returned data is not connecting. The LTE icon is flashing on and off repeatedly. Calling is working fine. I've checked APN settings and restarted the phone a few times and it hasn't fixed the issue. Any other suggestions?
mikeman123
This worked! Thank you!!
pakmode
You can also try taking out your sim card and reinserting it.
If that doesn't work put it in airplane mode for a minute before putting it back into normal mode.
paulie
shut the phone down and leave it off for a good 5 min ?
