08-03-2017 11:55 AM - edited 01-04-2022 02:26 PM
08-09-2017 06:45 AM
nothing
08-04-2017 12:13 AM
First, check to see if you can connect to the USA network. If not, go to network manually search the network and conect to USA network.
08-03-2017 08:35 PM
Hi @Kevdon,
Your post contained your phone number, so I removed it in accordance with community guidelines. This is a public community that anyone including Google search can read.
I also moved your post to it's own thread for better visibiltiy.
Did you try manually selecting AT&T or T-Mobile network? Worth a try if you haven't.
