Reply
Highlighted
Re: Receiving calls from Mexico
Just posted a similar question. My friend actually called his carrier who was told that my number did not exist.
Did you ever resolve this?
Accepted Solutions
Highlighted
@vicgal wrote:
My friend verified my phone number several times, we reviewed using +1 before the country code which is what I have used all the time using this carrier when calling Canada and the US from Mexico. On initial enquiry with his carrier, he was told that "this number did not exist". I have a relatively new area code "236" - would this impact the message he was given?
In any case, he will call the carrier again. With reduced hours because of Covid-19, and his working, this has been problematic!!
If this is still a problem, then it may be the area code. Others have had issues receiving calls to new area codes.
Here's a workaround: get the app from fongo.com, or textnow, and select a number with an old area code. Forward calls to your PM number and have your friend call the fongo number.
Alternatively, your friend gets a fongo number and calls you when he has wifi.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
All Replies
Highlighted
Unforutnately, that's a matter that your friend is going to have to get fix at his carrier. That doesn't sound like something that Public Mobile can help with.  This sounds like a routing issue.
This original thread that you posted in appears to be about receiving calls form people who were not saved in the contact list. When someone calls from a number not saved in the contact list or if no number shows up, some phones are set to reject these phone calls.
edit:  I have sepearated your questions into a sepearate thread.
Highlighted
Thanks for your response.
His number is listed in my Contacts, so that is not the problem.
I will forward on your answer to him so he can contact his Mexican carrier. I do know that I have had that carrier in the past, and was able to call Canada.
Highlighted
Honestly it could be just that theychanged the number or he put in the number wrong or area code. Even for a long distance number, the standard rates apply message would come up as public mobile has no say it what number aractive they just dial it through
Highlighted
To clarify, if the informaiton that your firend's carrier is accurate that their end shows your phone number as not active, this can't possibly be an issue with your phone's settings.
Even if you had your phone set to auto-reject calls from unknown numbers or even if you specifically block him from calling you, his call would still go to your voicemail and he would still be able to leave you a voice message.
Highlighted
For the Public Mobile customer, there's no need to talk about rates. First, Public Mobile does not have any pay-per-use rates. Second, it never matters for an incoming call where the call is coming from.  As for any charges that might apply, that's between @vicgal's friend and the friend's carrier.
Highlighted
No I meant when you call long distance an operator recording usually states that long distance may apply.  Leading into another response that sometimes VPNs are the issue .  That it’s registering you in a different area that you actually are
Highlighted
Just referencing the automatic recording but actual informations for any rates or services if that clarifies it
Highlighted
Highlighted
Just to make it proper...in Mexico calling here..
00 to get international
1 to choose Canada
236-xxx-yyyy
+ can often be used instead of 00
