Re: No incoming outgoing calls or messages
nabil114
I cannot make outgoing calls now.
2 REPLIES 2
gblackma
@nabil114  You can look at adding th $5, 500 minute Canada wide addon In the meantime add a voip app such as TextNow and use it over WiFi to make/ receive / send calls and texts for free in Canada and to the US.
Also, given the current situation, you may also look at a temporary upgrade to the $25 plan.  See article on how to do it https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
ShawnC13
@nabil114  what plan are you on?  If you are on a limited minute plan could you have used up all of your minutes?
