05-03-2019 11:01 PM - edited 01-05-2022 04:45 AM
New User wanting to switch
$15 plan
Does it include unlimited incoming texts? Unlimited incoming Picture texting included too?
Also, can I sign up for auto pay in the future and still get the bonus data? What happens when I run out of data?
Thanks
05-04-2019 09:30 AM
Thanks for reply. I'm looking at so many providers that I'm confusing their terminology.
In reviewing plans by this carrier, I see that you're 100% accurate.
05-04-2019 09:11 AM - edited 05-04-2019 09:13 AM
@caseythebeagle wrote:Thinking of getting the $15 plan for my daughter. I'm curious about the definition of international texts. Does that include texts within Canada?
I ask because on other plans they specifically say Canada texts. I want to be sure that international texts are not strictly international and they, in fact, include within Canada.
It means everywhere. (Edit: while in Canada)
What plans say Canada? There're no Canada-only texting plans here.
05-04-2019 09:01 AM
05-04-2019 12:52 AM
Hey,
Yes the MMS is unlimited both the ways. Make sure you keep your Mobile net on in order to receive/send it. Set-up Autolay at the beginning and bonus simply stops working after it's use.
05-04-2019 12:19 AM
@PhiliPTran wrote:New User wanting to switch
$15 plan
Thanks
@PhiliPTran Yes, your plan has unlimited incoming texts. When you have picture texting, you need to have your wifi or data on. After you have your first autopay processed, you will have $2 reward shown in your account within 2 days.
If you are running out of data, you have buy an add-on data that will depleted until you use up the data. Usage of the monthly plan goes first, then your add on.
05-03-2019 11:09 PM
$15 plan
Thanks
@PhiliPTran Yes unlimited incoming texts including MMS are included. To get the data you need to setup Auto-pay during activation. When you use up your data it just stops working. There aren't any extra charges.
05-03-2019 11:06 PM - edited 05-03-2019 11:07 PM
$15 plan
Thanks
Texts both directions are unlimited. MMS unlimited both directions too.
It's best to sign up with Autopay from start because you get lower price. When you run out of data, it stops working.
