Purchased add on is not being applied
bananagirl
I have a 1GB add on that is not being carried over along with one I recently purchased. Which is the 200mb for $10. The $10 funds is shown in my account but I cannot use the data on my phone. Any help with this is greatly appreciated!
2 REPLIES 2
Everything is purchased via available funds.  You must add funds to the pool, then select the add-on you wish to purchase.
You're not buying it twice, you're adding funds, then using them afterwards.
Samianauman
It's a 2 step process first you purchase add on and fund get transfer from cc to public mobile funds then you buy again same add-on from available fund.
Also since you mentioned its didn't rollover your 1gb data I would say contact mod
Contact any moderator by private message to help you with the process.
In your private message the following info
* PM account email address
* PM phone number
* Detailed explanation
Here is the link for how to contact moderators http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updiated-Contacting-our-Community-Moder...
What you do click on link the webpage will open. You will see a mod team click on any name then scroll down all the way and click on send a private msg then explain your problem
Thanks"
They will fix it for u
** I am not a Mod, please do not include any private info in a private message to me.**
