03-03-2017 09:03 AM - edited 01-04-2022 01:33 PM
I am considering bumping down my service to province wide. I do have a question though. If the person I am calling has my provinces area code say Ontario, but is visiting Quebec. Would I need to add a top up in order to call them? or would it still be considered part of my plan? Would like to make sure before changing my service on the 7th, as my husband travels regularly for work but I dont typically leave the province and have no intentions in the next 90 days.
03-03-2017 02:05 PM
Thanks 😄 @srlawren
03-03-2017 01:57 PM
Great description, @Mary_M
03-03-2017 12:18 PM
Yes exactly, as long as you're calling a number within your local calling area, and his plan allows it, you shouldn't have any issues 🙂
Cheers! @kat101,
Mary
03-03-2017 12:10 PM
@Mary_M I think so. So ideally, his plan would keep Canada wide, and I can downgrade to province wide and we shouldn't have any issues. Thank you.
03-03-2017 11:51 AM
Hey @kat101
That is a good question! Technically, you should be able to place the call since you're calling a local number. However, your husband's plan need to include incoming calls while being in another province, or permit them - if his plan does not support this, the call won't go through on his end.
Does this make sense? 🙂
Mary
03-03-2017 10:20 AM
@Luddite Thats what I am hoping for. keep Canada Wide on his and province on mine.
@CaNuCk07 Thanks. i did read through the link before posting. It seems very focused on my location not nessarily his which is why I asked. Just trying to make sure that I can still call him if I need too even if he is out of the province.
@Mary_M Can the Mods make a comment on this before I change my acct please?
03-03-2017 09:44 AM
@Ludditeawesome to know!
03-03-2017 09:43 AM
@CaNuCk07 wrote:@kat101 Your husband would still be out of your calling area, om quebec cell towers, so you would need to get the calling long distsance package.
This is a good link.
Dont' think this is correct. When you call an area code within your province that call is free. Whether the recipient receives the call while outside the province depends on their plan not yours.
03-03-2017 09:14 AM - edited 03-03-2017 09:45 AM
@kat101 This is still a good link! 😄
