Please can a moderator change my plan early
qcriderfan87
I used to be able to change my own plan early as long as I switched plans. Now, only, the option ‘top up’ exists, this is a change for the worse. I ran out of data and I’m on the highest data plan, I don’t mind paying more but it’s very inconvenient waiting for a moderator to make the plan change go early, I’m wishing to renew early the $50 8.5gb 3G plan and would like to stay on the same plan. I would also accept the $60 8.5gb plus 2.5gb roaming in u.s. plan. If
a plan change must be made. I don’t care about losing minutes or or rewards or anything like that. Just change my plan, and do it quickly, please and thank you. 🙂
qcriderfan87
you are right thanks 😉👍
GR
@qcriderfan87  if you're on the 50$ plan you should be able to switch to the 60$ plan in self serve
qcriderfan87
Don’t tell me about data add-ons. I recently was made aware that they roll-over but I still think they are a bad value. It’s been less than 2 weeks and I’ve already used 95%. I just reloaded my
phones OS, so I will tweak it to use less data. Again, thanks.
