Reply
Plan renewal issue
So my plan reset on December 7th (Today), I thought my plan was $45, but it was $50.  I put $45 into my account the night before.  I didn’t have enough funds on my payment method so it didn’t go through.  Today I changed my plan back to the $45 plan with 6.5gb 3G data.  My account now says I have that plan with talk and text, but no data on the overview even though it says it’s included as part of the package. Please help!
Edit: My data, calls or texts do not work.
Re: Plan renewal issue
If your plan is listed as Active now, try rebooting your phone.   Could just need a kick to reset.
If that fails, try setting your phone in Self-Serve as lost for 5-10 minutes, then turn off the setting, followed by a reboot again.
Thanks very much it worked!
@Bitflipher was it the reboot or the lost/stolen trick that worked?
Was it just the reboot required, or the lost status change?  Just curious.
The lost status change for 5 minutes, didn’t even need to reboot after that.  A regular reboot didn’t do it.
