Plan details
token
Hi there. I am looking at the $50 and $60 plans and have a few queries..
1) It seems the only diff is the 2gb usa data roaming, is true?
2) Does that mean 2gb anywhere in usa ? (continental?)
3) And is the 2gb usa data at 2g or 3g or 4g speed?
4) Is there ever any data roaming inside Canada or data can be
used anywhere in Canada that the phone works?
5) So do I understand correctly that Public mobile uses the full Bell network?
6) Can calls be made from anywhere in Canada to anywhere in Canada or usa?
Or can calls b made from anywhere in Can or usa to anywhere in Can or usa
These are probably common questions and I tried searching with the robot
but no success
Thank you
8 REPLIES 8
GR
@token  check your inbox.  Click on the envelope at the top of the page next to the bell
token
noope.. what is it?.. Whoops found it...
Will you be my friend?
GR
@token   if you switch to public mobile you do know of the 10$ friend refferal credit?
token
Well, that seems downright friendly.
Way to go Public mobile! Smiley LOL
Thank you for quick, patient & informative responses
GR
@token   on the 60$ plan you can talk and text from anywhere in Canada and the US to anywhere in Canada and the US.   The 50$ plan only works in Canada but you can call and text to the US from Canada.  The text and mms message is international from Canada on the 50$ plan and from Canada and the US on the 60$ plan
token
ah tks.  Ok so ... $60 plan gives 2gb anywhere usa data at 3g speed.
Please help me to understand from $60 plan, what means:
  • "Unlimited Canada / US Talk & Text"
Does that mean make calls or send texts from
anywhere in Canada or USA to anywhere in Can or usa?
(or just send/call from Canada to Can or usa?)
Does that include multi media mesgs and does that
include all international text and multi media msgs?
(like in the $50 plan)
And for $50 plan does
  • "Unlimited Talk Canada & US"
Mean make calls from anywhere in Can or USA
to anywhere in Can or usa. (or just from Can to Can or usa?)
Also it seems $50 plan includes all text sent from Canada only?
Sorry if these questions seem silly.
I come from mobilicity/wind
(Freedom/Chatr) lines so always
feel need to make sure about "zones".
And they don't really give many details in the
"details" description on the "plans" page
Also I see now I have posted this in wrong section, apologies.
but no success
Thank you
$60 plan
1. and call/text in US
2. yes - not just continental
3. I've read claims that it would be 4G
4. anywhere in Canada with Telus/Bell service
5. Telus and Bell
6. yes (both are the same question)
GR
@token
1. Yes
2.yes
3. 3g speed
4. no, roaming in Canada. Works anywhere.
5. Bell/Telus
6. Anywhere in Canada to anywhere in Canada /USA on the 50$ plan..  Anywhere in Canada/USA to anywhere in Canada /USA for the 60$ plan
