Reply
Highlighted
Re: Phone Calls Not Working (Texting Works)
Highlighted
Thx a lot..tht was the problem...great help ...thnk u
Highlighted
I have same problem. Does the solution come from offically public? Who 's solution is 100% correct?
Highlighted
I had run out of mins ......hence no calls just text worked ...its back to normal new billing cycle started.
Highlighted
I can’t make calls ..
Highlighted
@Tearrahudsonxo Hello what plan are you on?
Highlighted
@Tearrahudsonxo Is it a sudden issue or is this a new phone? What phone do you have? Make sure it supports the 3G bands of Public Mobile? If they are not supported then you won't get voice.
Highlighted
@Tearrahudsonxo are you on the 10 or 15 dollar plan? did you run out of minutes?
