Paying for a small amount of data--but it is not working
wbc
Hi there
I have asked IT for support with this but no reply. I have an old I-Phone that I use mostly for staying in touch with home when I am out working. So just 250 MB data but it does not work for me...can only check email when connected to WIFI and cannot send or receive photos.
wbc
Thanks, yes, IPhone 4. I will give the link a try.
mimmo
@wbc  when you say old what model?
iPhone 4 need a special procedure.  I believe all the info is in the post @Anonymous linked to.
tabi159w
Try to reset your APN settings to the default. Are you sure your data is active and not used up?
@wbc wrote:
Hi there
Have a read through this.
gpixel
@wbc reset your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
