03-08-2019 01:02 PM - edited 01-05-2022 03:37 AM
03-08-2019 04:26 PM
@muuuhhiiike did you maybe set a data limit in your phone's data usage settings and have it stop your data after 4GB of usage? If you don't remember doing this, it's still worth checking as it may have been a default on the phone, or you may have set it a long time ago at another carrier and forgotten.
03-08-2019 02:09 PM
@muuuhhiiike, double check your internal data usage counter isn't set for a limit. If you're not already on a 30-day or 90-day data monitoring app, you should get one.
The stock app on most devices will not work properly with 30- or 90-day cycles.
03-08-2019 02:07 PM
@muuuhhiiike sorry to hear about that. Just wondering where you are checking the data usage ? means on your personal device or on the PM account data usage ?
Are you finishing your data before 30 days ?
if yes, and you are checking data usage from PM account only then please send a Private message to the Moderator by clicking on this link @CS_Agent
*** Please note: I am not a Moderator ***
