No Service??
Cass4200
Why do I have no service when I just paid my phone bill
13 REPLIES 13
mpcdesign
@Cass4200  and @amogh12, as you know, with the chaos of the pandemic across the world and in your own backyard, all lines are busy.  I guess too many folks calling the ISP to figure out what was happening - an issue with the number of lines going into the business, all 'circuits' busy for their incoming line.
It is what it is. Other cell phone providers will have these issues. Hence, why am the OG that still has a landline, that I don't have a problem? Granted, I did do a telephone conference from my cell phone with no issues. Luck of the draw?!
will13am
Outage confirmed even on mobile syrup.  If phone service is absolutely critical at all times, it is best to have overlapping service (e.g., home phone supplied by a different provider than cell phone).
https://mobilesyrup.com/2020/03/31/telus-service-outage-western-canada/
Cass4200
All good it’s back
@Cass4200 wrote:
Is it out is Saskatchewan?   Because that’s where I am and it just stopped working randomly.  I was using it just fine all morning then bam gone
Higher than normal call volumes have impacted Telus networks in the west.
ltopo
Just got back in Calgary.
Look at this map for outages
https://www.telus.com/en/bc/outages
Cass4200
hairbag1
Should be back to normal now...at least in interior of BC it is.
@Cass4200 , @kcal , and @amogh12  there is an outage affecting Western Canada. In the meantime add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. Check to see if you are affected. https://www.telus.com/en/bc/outages . If not, please say so in order to get more help. Thanks.
JoyLuck
There is currently an outage in some areas ...mostly Alberta
kcal
should be back now
ddeep91
There is an outage for Telus networks in some areas.
You can check the outage map HERE.
amogh12
same here ... is it because Telus's AB wide no service affecting us ?
