10-13-2021 01:26 PM - edited 01-06-2022 03:46 AM
10-13-2021 07:39 PM - edited 10-13-2021 07:40 PM
@esjliv : You are missing nothing. It's how that user rolls. CSA!! everywhere all the time. What is the point of having this crowd-sourced support idea if all anyone does is dump customers off to the CSA's at every question? Who will then proceed to give the customer the company policy. And even be wrong about the question from the customer.
Edit: lol
10-13-2021 07:38 PM - edited 10-13-2021 07:39 PM
@Sallygeng OP say >> I have $25 plan free talk and text plus 1 G data, and I see there is 2 G promotion data on my plan but I am not getting the data to use, is there anyone know why?
@esjliv wrote:@Anonymous -
There is basic data trouble-shooting that should be done or asked of the OP before jumping onto CSA's here.
The Promotion is showing, so why ask CSA to look into this...Am I missing something?
so for that answer they have to ask to CSA, But your right we need to them do first troubleshooting device and network and maybe they will working if not working the need to ccontact to CSA,
esjliv > thank you..
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
or can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone
This is quick and simple,
and if still not fix it you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,
10-13-2021 07:27 PM
@Anonymous -
10-13-2021 04:01 PM
Good for You! You stay within your plan data allotment each month. Maybe start monitoring how much data you do use every month. If its under 500mb per month you may be better off saving $10 per month and opting for the $15 plan.
Then on average the 2GB Bonus would last about 8 months before a $15/1GB data add on would be needed. ($15/1GB÷4=$3.75p/m) $15 plan +$3.75=$18.75 per month. The $5/500min add on can supplement the 100 outgoing minutes on the $15 plan. For most customers they may use an additional 100 min=$1. ($18.75+$1=$19.75 per month)
Do you see the 2GB Data add on under "My Promotions" on the right side of your overview page or on the left side at the bottom half under "My Data and Add ons"?
10-13-2021 03:38 PM
Normally you use the promo data 'after' you have used all of your plan data.
If you have 1GB plan and some promo data then you ll see the usage of promo data after whole 1GB data has been used up.
You ll able to see the updated data usage in my account -> overview.
10-13-2021 02:17 PM
@Sallygeng...the 2 GB promo data will stay on your account until you use it up. It gets used only when you run outta regular plan data. If you don't use all your regular plan data in the 30 days...the promo data goes untouched...until you do need it.
Perdy good deal eh.
10-13-2021 01:35 PM
go sign in to Self-Serve, to review your account History data,
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
10-13-2021 01:34 PM
@Sallygeng : You will only get to use that data after using up all your 1gb plan data before the next renewal. Then at your renewal you will go back to using the plan data.
10-13-2021 01:33 PM
@Sallygeng wrote:hello
I assume your cellular data is turned on?
If so, since when does the problem occur?
Can you post a scrennshot of your overview page?
10-13-2021 01:30 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck..
