05-09-2018 06:34 PM - edited 01-04-2022 04:15 PM
05-09-2018 09:51 PM
@meocon wrote:@NDesai I saw your signature you're not MOD so how can you remove or edit another user topic? just curious thanks
Exactly this:
@srlawren wrote:Levitation, super-strength, ability to dodge bullets*, super hearing, that sort of thing.
*proverbial ones of course
Super hearing is my favorite 😉
05-09-2018 09:25 PM
05-09-2018 09:14 PM
05-09-2018 09:11 PM
05-09-2018 08:25 PM
@Wpswkd38 The picture included your account number and so i removed it. Please do not post any personal information as this is a public community.
05-09-2018 07:47 PM - edited 05-09-2018 07:48 PM
@Wpswkd38 usually tether hotspot takes lot of data usage but if you don't think you have used that much data you can contact Mod to double check for you
I recommend you send a private message to the moderator team and ask them to investigate. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
How long until a moderator replies?:
How can I view my private messages between myself and a Community Moderator?
05-09-2018 07:14 PM
use your cell phone to tether into a windows system, they will consume few GB per day, it has its limit thought. The latest windows doesnt even allow you to disable it in the easy to use interface. Many had that issue from hotspot from the phone.
05-09-2018 06:55 PM
@Wpswkd38 when your data plan disappears from the Overview page, it means you have consumed the full amount. Unfortunately it's extremely easy to burn through 1GB of data when tethering. I'm assuming you were tethering a PC. I know for example right now Microsoft is rolling out the April 2018 Windows 10 updates which are likely large enough to consume almost or all of 1GB of data if that happened to start downloading while you were tethered. Did you set your tethered connection on your computer as a "metered connection" so that it would avoid doing some intensive things like Windows and Store updates?
Alternatively if you were streaming some Netflix or YouTube videos while tethered and they defaulted to 1080p or 1440p or 4k, they can easily use up a ton of data very quickly.
