Reply
Miss print??
Added a add on special 15$ For talk,text and data. When I cash out it’s missing the text.
Re: Miss print??
You should contact a moderator.
Moderator can be reached at
Re: Miss print??
@jordanhunt3030
Known glitch in the system for the new $15 plan.  You should still get the unlimited incoming minutes.  When I changed to the new $15 plan, it showed the same thing.  I tested yesterday and my plan does have indeed unlimited incoming minutes.
No need to contact moderator unless your plan does not work as stated.
Re: Miss print??
I’ll try it I guess
GR
Re: Miss print??
Check in your account now, mine says the unlimited incoming since yesterday!
