Made a silly mistake with my plan
Kraekin
Hey there,
So I just went and did a plan change, well really what I wanted to do was just renew early so I would have data instead of just waiting for 3 days til the renewal date. But I did make a silly mistake, I left out texting and didn't even realize it cause either way it costs $50.
I was wondering if there was any way possible one of our awesome mods to be able to add it for me or am I outta luck?
@Shazia_K @Mary_M
Thanks in advance 🙂
2 REPLIES 2
srlawren
@Kraekin this is a fairly common mistake, and unfortunately requires moderator assistance to correct ( as @mimmo mentioned).  If you're not sure how to private message a moderator, there are two links in the italic text at the bottom of this reply that explain the process.
mimmo
Send the mod your account info phone number and plan you want. That way you avoid the mods asking for it.
