Long distance
woodrow1
When I try to call Ontario or British Columbia on the $25.00 plan with unlimited calls across Canada keep getting long distance message and it will not dial the number?
37 REPLIES 37
@woodrow1
Maybe try the following:
Reboot phone
Network reset
Toggle airplane mode on, then off.
If not working still, then you may need to contact moderator for help.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
Google says area code 205 is an Alabama number in USA??
Area code 205 is found in the US state of Alabama. Primarily servicing the city of Birmingham (population: 445687), area code 205 covers 20 counties of Alabama.
woodrow1
Area code(205) and
@woodrow1 is this happening to all your long distance calls?  Or just this particular one? What area code are you trying to dial?
Elaborating on @Jb456 's answer. Since you have Canada wide calling all your contacts should be added with 11 digit numbers ie 1 ### ### ####.
woodrow1
I tried that no change.
Jb456
Try putting a 1 infront of number
