Reply
Re: Long Distance add-on problem
@ChuckYeah wrote:
@Turtluv wrote:
Thank you! Thank you!  Couldn't see that question mark for the life of me and there it was, hiding in the bottom right corner.  LOL  Let's see if the bot can help. :-)
Try this while you wait for a reply. It may give you some insight and possibly a place to negotiate/argue from.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Long-Distance-add-on-problem/m-p/484474...
"Destination Location" worked best for me as most of my calls were to or from one province.
I'm 5 hours from the border.  :-(
No.  I just got the add on "just in case".
I'll try it again using Destination, etc.  I'll see what happens.
@Turtluv wrote:
The link
just takes me back to my original message and the thread.
No, it takes you to @ChuckYeah's first message in this thread.
I did as suggested. Scrolled through 550 pgs. No way that there 200 min unless they count me calling a 1-800 to place orders, etc.
Thank you so much for everyone's help.  The moderator solved my problem.  It was an add-on for 200 min that, when it was used up, it's gone.  Problem solved!
