08-20-2019 11:00 AM - edited 01-05-2022 06:31 AM
I was just wondering if the old $120 120GB / 90 days plan is getting LTE speeds. Is it worth changing to the $40 4.5GB / 30 days plan at 3G speed?
08-20-2019 06:15 PM
@Iam31415 wrote:I was just wondering if the old $120 120GB / 90 days plan is getting LTE speeds. Is it worth changing to the $40 4.5GB / 30 days plan at 3G speed?
You wrote 120GB. That can’t be right?
08-20-2019 11:58 AM
Yes, unless the plan description mentions "3G" you are on full LTE.
Now that all the talk /text /LTE plans have conveniently been eliminated by getting rid of the plan builder, I personally would hold on to that 2016 fall promo plan as long as it fits my needs.
However it's a decision only you can make. Do you need more data? Are most of your calls Canada wide? (If the later: would the $5/500 CW minutes add-on be enough?)
Thank you for the clarification @wetcoaster. I'm definitely keeping my old plan. Will just get add-ons when I need it.
08-20-2019 11:43 AM
@Iam31415, that old plan is full speed LTE and very coveted. If you don't want it, I would gladly take it off your hands. Only problem is the phone number has to go with the transfer.
08-20-2019 11:38 AM
