Reply
saiii
Is it Holiday giveaway data still valid for now?
from my account overview it still shows i have holiday giveaway 2gb addon, after i fnished using the 1gb at 3G speed, can i still use the remaining 2gb addon?
thanks!
Accepted Solutions
Quigley
Re: Is it Holiday giveaway data still valid for now?
Yes that's right after you use your monthly allotment
All Replies
Quigley
Triguy
Yes, the 2GB add-on will remain in your account until they are used up.
Asher2
Yes you can use the free 2GB addon, forever until all of the 2GB is used up.
hairbag1
@saiii...
once your regular plan data (500MB + 500MB's) is exhausted, then your Holiday Giveaway 2GB of data add-on take over until next renewal (when you get a fresh batch of regular plan data). If you still have any Holiday data add-on left at renewal...it'll just keep rolling over until you do consume it...even if that takes several months or more.
Sweet deal eh !!
Bear2
From what I have been told the bonus holiday minutes and data will remain in your account until it has been used up. If you don't use it it rolls over to the next month 🙂
