11-15-2018 10:41 AM - edited 01-05-2022 02:29 AM
11-17-2018 08:58 PM - edited 11-17-2018 08:58 PM
@Jaidenkristin wrote:I restarted it and got someone to send me a text and I still haven’t received it. My messages will send fine I just won’t receive any responses
Are you still stuck? If yes, and you use an iPhone the correct settings are:
Settings >> Messages >> iMessages ON; Send as SMS ON; MMS ON >> Send & Receive should show your phone number and Apple email address id
If your phone number is not showing, turn Messgaes OFF then ON after a few minutes.
For MMS to function cellular data and roaming must be ON.
11-15-2018 11:30 AM
11-15-2018 11:01 AM
@Jaidenkristin wrote:My screenshot doesn’t show up in my reply on my phone so I don’t know how to do that
Well it's ok for now you got it off.
So how'd the restart go?
11-15-2018 10:59 AM
@Dunkgirl wrote:@ShawnC13I was wrong about this too thanks to @Anonymous explaining this can be done in the plan builder. Seems awefully expensive but at least there is an option for ONLY TEXT.
Truth be told, I thought the same thing then went to BYO to see if it was possible to select only texting.
11-15-2018 10:59 AM
11-15-2018 10:51 AM - edited 11-15-2018 11:03 AM
Oh. I see I got a Bravo.
This was originally the suggestion to remove private info. The OP did.
11-15-2018 10:51 AM - edited 11-15-2018 10:52 AM
@ShawnC13 wrote:
@Jaidenkristin wrote:I just purchased a $20 texting plan, I can send text messages but I can’t seem to receive them.
I see a $20 unlimited talk plan and at $25 talk and text plan. If you paid $20 are you sure you have texting? As well did you port your number in from a previous provider? If so and you are able to send texts but not receive them your port could be stuck.
11-15-2018 10:49 AM - last edited on 11-15-2018 10:53 AM by NDesai
I am new, I did not port a number. I will also try restarting my phone.
i built my own plan and here is a screenshot
11-15-2018 10:49 AM - edited 11-15-2018 10:52 AM
Edit to add sorry saw the build your own plan pricing as well.
11-15-2018 10:45 AM - edited 11-15-2018 10:45 AM
Can you post a screen shot of your self serve?
I don't see a $20 texting plan available to purchase
$20 = Unlimited talk (no text no data)
or $20 = Data (no talk no text)
There is a way to get there with the BYO.
OP: Did you restart the phone?
Are you new here? Did you port in a number?
11-15-2018 10:42 AM - edited 11-15-2018 10:49 AM
I see texting plans for $10 and $25 but nothing for $20. How did you get this offer?
Thanks @Anonymous. I see the texting plan is available from the plan builder. No calls. No Data. Only text $20.
