International Roaming (NOT USA)
cado
Hello,
I'm going to Brazil and I'd like to know if it is possible to activate roaming while there, as all I see is roaming to USA.
Thanks
7 REPLIES 7
pakmode
@wilsoncheng wrote:
I wish Public have international roaming.
I know most people will say : Buy local SIM card. Or use Fongo.
BUT. sometime I do short stay like just 2 days at a country, when I do a connection.
What roaming can do, and other solution can't , is I can walk on the street and still able to send/receive message, look at map, and receive phone call that call to my Canadian number.
Does Public ever plan to have international roaming?
My honest to goodness guess would be - no.  They will never have intl roaming.
US roaming just came available 10 months ago.  That's huge progress from the non-existent prior to that.
if you want/need more roaming options, I don't think you will find them here anytime soon.
Sorry!
wilsoncheng
cado
Thanks everyone. I guess I'll stick with the local sim solution then.
Mana
@cado download fongo and use it over wifi, plus you can use other apps over wifi.
Or if you have an unlocked phone, you can buy a local sim when you land there at the airport.
stonechucker
No roaming available other than the US.
If your device is unlocked, look for a local sim.
NDesai
Sorry, no roaming outside of NA.
