Incoming calls when traveling outside province
Ooops
Hello Mods:
I have searched this threads and most posts indicate that incoming will not work without add-on if you are traveling outside home Provine.
I have experienced otherwise.
I have PM province-wide plan and live in Ontario (Ontario number with 613 area code). I was traveling to Calgary, Alberta in April for three weeks and was able to receive incoming calls on my PM Ontario number - (No add-on for long distance); the incoming calls mostly were from my home - Ontario and also local calls. My outgoing worked for only within Alberta calls.
So can the members WHO HAVE USED province-wide plan WITHOUT add-on outside home province please share and shed some light if we do not need long-distance add-on for INCOMING calls when traveling outside home-province
Appreciate the community helping each other.
60 REPLIES 60
