09-20-2019 06:32 PM - edited 01-05-2022 07:12 AM
09-20-2019 11:37 PM
I am not going to repeat what was said on this thread.
When you arrive at your US destination your US roaming add-on or plan,
1. enable data and roaming.
2. restart your phone. You phone will connect to AT&T or T-Mobile netowrk. The APN will be setup for you on the connected network.
09-20-2019 07:37 PM
@BoomDigital You can think about having Roam Mobility, but you need to buy a new SIM card. You will have a number that you can forward your current to the US number when you travel. Roam Mobility charges by day and unlimited data.
09-20-2019 06:52 PM
@BoomDigital wrote:I want to make sure that I can receive calls and text from Canada with my same public mobile sim card, number etc. I also want 4 gbs of data as well. How do I set this up?
@BoomDigital Best to switch to the $60 plan. you will get 2GB of data and then you can add a US Roaming data add-on as needed.
Another option is to purchase a prepaid card when you are down there. Something like this
but you will need to select a US number for it to work.
09-20-2019 06:40 PM
09-20-2019 06:33 PM - edited 09-20-2019 06:35 PM
Yes Public Mobile has Roaming Text, Data and Call Add ons to the States.
Follow this guide by @srlawren
However for your 4Gb data you will need to purchase 1Gb use it up or wait until it expire before you can get another one.
