07-04-2020 07:03 PM - edited 01-05-2022 11:58 AM
07-04-2020 07:55 PM - edited 07-04-2020 08:04 PM
What do you mean " it's still throttled " ? As soon as you buy it correctly, it'll work. Log into My Account / Data and Add-ons to see exactly what you have and let us know.
07-04-2020 07:53 PM
Well my phone just reconnected to LTE. Thx for the help. You guys are great.
07-04-2020 07:52 PM - edited 07-04-2020 07:53 PM
07-04-2020 07:50 PM
@Eugenius1977 wrote:
You will need to purchase the left upper data add on 1GB for $15 as shown your screenshot
07-04-2020 07:48 PM
@Eugenius1977 wrote:thanks for all the great help. I have 2 add ons now. So I am able to go online but it still is throttled. Maybe they have to remove the us roaming add on? And there is only one optionon my end for 1gb addon
Having the US data roaming add on should not throttle your data.
Unless your original plan was a grandfathered LTE plan, most data add ons for the recent PM plans (except for the 1GB LTE data plan only) will be 3G throttled.
Moderators should be able to remove your USA roaming add on.
07-04-2020 07:46 PM
07-04-2020 07:45 PM
07-04-2020 07:39 PM
The interesting thing is that the 1GB USA roaming data add on is $20. (not $15)
Maybe screenshot your overview page with the data add ons.
07-04-2020 07:27 PM - edited 07-04-2020 07:29 PM
@Eugenius1977 hello you can contact a moderator for a refund just explain that you purchased the wrong one to contact them click on the? Lower right hand corner and ask Simon to speak to a human this will generate a ticket to speak to a moderator mention purchased wrong add on look for a response Top right corner the little envelope icon response time is usually between 2 to 48 hours you will have to go back into your self serve and purchase the proper add-on have a great day
07-04-2020 07:23 PM
I think you should contact a moderator. I believe there might be an error with self serve if you purchased the $15 1GB of data but got US roaming...
07-04-2020 07:19 PM
I did and it still says 15$ 1gb us roaming
07-04-2020 07:18 PM - edited 07-04-2020 07:21 PM
@Eugenius1977 wrote:There is only 1 option for 1gb 15 dollars and that's what I purchased
There are two options for data at $15 you selected the wrong one.
07-04-2020 07:18 PM
@Eugenius1977 try these two things to kick start your data.:
1.Restarting your phone. Turn your phone off, wait 30 seconds and restart.
2.Putting your phone on aeroplane mode for 5 minutes. Take it off and restart.
07-04-2020 07:15 PM
@Eugenius1977 wrote:Yes it was purchased
You will need to contact the moderators for assistance. You can do that bu clicking on the "?" in the bottom right-hand corner of the screen. See if they will reverse the charge and allow you to add the correct add-on.
07-04-2020 07:15 PM - edited 07-04-2020 07:16 PM
@Eugenius1977 PM is prepaid thete are no refunds. Contact the moderstors, explain that you purchsed the wrong add and ask nicely for a credit. You may get one.
There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
In the meantime , buy the 1gig for $15.
07-04-2020 07:14 PM
07-04-2020 07:14 PM
@Eugenius1977 wrote:Hello there. I can't seem to connect to anything in. I had used all my data...so I purchased a 1gb add on. Now why can't I still not have any data.it says H+ if someone can help with this issue that would be awesome. I bought 1gb of us roaming. I need help asap
Purchasing add-ons is a two-step process. The first time the funds actually got o Available Funds. If you log in and see the amount of the add-on in your Available Funds go and "repurchase" it. Sorry just noticed you purchased the US roaming add-on. That will only work while in the US and is only good for 10 days,unlike the other data add-on which stays in your account until it is fully consumed.
07-04-2020 07:11 PM
07-04-2020 07:10 PM
I am in Ontario wasaga beach. Can u switch it over for .e? Or do I need to purchase another one
07-04-2020 07:06 PM - edited 07-04-2020 07:07 PM
@Eugenius1977 @Hi the us roaming only works in the us it is also a two step process to buy it the money may still be in your account you can check your self serve to see if it was purchased
07-04-2020 07:05 PM - edited 07-04-2020 07:06 PM
@Eugenius1977 are you in the States? If you arent, you bought the wrong add on. You need the 1 gig for $15. Stay safe. Please let us know where you are for more help. Thanks.
