I cannot receive or make a phone call.
signofgrowth
Hi,
I cannot received or make a phone call starting mid January 2020.
9 REPLIES 9
Johnc2780
When this happened to me, I did the following:
1) turn the phone off and remove the sim card.
2) restart the phone without the sim card then restart the phone and shut it down again.
3) Re-install the sim card and allow the phone to re- register it on the network.
You should now be able to use your phone again.
ajkm
Is your account set up for AutoPay - with a credit card number attached to your account via SelfServe so that your plan automatically renews every 30 days?
What was the date on which you originally set up your account?
Is this only month 2 or has your account already rolled over from one 30 day period to the next?
More information would allow us to help you further.
CannonFodder
@signofgrowth  Along with what others have said, there's always the simple, yet popular, try resetting the phone, and see if anything changes.
cynicustracks
@signofgrowth wrote:
Hi,
Of course check to see if you have enough credits. But could it be a hardware issue? Have you travelled outside the country recently and changed your sim card? Maybe check your settings.
geopublic
Hi,
@signofgrowth  Dial 611 from your phone. If your account is suspended then you need to renew your plan.
Hi,
@signofgrowth Do you have enough funds and minutes? Is your accont active? If yes, then click the "?" in lower right side of the page, type "contact moderator", and follow directions. OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Although this is good information there are things you can do before/while you are waiting for the Mods. We just need more information on your situation.
Staliger
Hi,
ChuckYeah
@signofgrowth Log into http://selfserve.publicmobile.ca and see if you have minutes left if you are on a limited plan. And make sure your account is Active as well. Does anything work?
krazykiwi
Hi,
Hi, Which plan are you on? Did you run out of minutes?
