How to switch to the $28 2.5GB data unlimited call and text plan
vivianzntj
A plan for QC users, $28 including 2.5GB data, is the original $35 one with monthly discount of $5 and $2 for autopay. (35-5-2=28)
I have already signed up for Autopay and also a QC user.
When I tried to change my plan, I did not find an option of $28. I only found the $35 one.
May I know if I switch my plan to the $35 one with autopay, is the $28 applied automatically?
If not, may I know how to change to the $28 for 2.5GB data plan?
Thank you.
8 REPLIES 8
@gpixel and @Anonymous I found it!  thank you both for the info.  👍👍
@gpixel wrote:
@RosieR its in a similar post as this one. @darlicious confirmed it with Catherine_T
*Batwoman signal engaged
 @gpixel , @RosieR
I think it was actually mimmo. Catherine_T confirmed.
@RosieR its in a similar post as this one. @mimmo  confirmed it with Catherine_T
@mimmo signal engage
@gpixel wrote:
@vivianzntj I'm not sure if pm fixed this issue yet, but there are customers who needed to speak with customer support mods to apply the promo
make sure to check your inbox(top right corner envelope icon) periodically, for a response
@RosieR it's for both existing and new customers. hopefully this is going to be our black Friday plans!
@gpixel thank you.  Where is it written that this is for both existing and new customers?
gpixel
oooops never mind.
Evanjms
Usually takes PM a day or so, but you should get a text confirmation of rewards/discounts applied to your account. I get referral notifications pretty quick, but they usually send out a monthly rewards notification. It should go through smoothly 🙂 If not, the moderaters will have your back.
Cheers,
Evan
 @vivianzntj : if your number is a QC number then select that $35 plan and they will add the credit afterwards.
Give it a couple few days and then send them a note if need be.
