Reply
Highlighted
Re: How plans work at Public Mobile?
Thanks. Where do I find how to set up the data? thanks.
Highlighted
You will find the latest information on setting up data in the knowledge base article Setting up Data (APN) on your phone.
Highlighted
Why do you need to change your plan before the renewal?  If i havent bought/paid for the plan, i should be able to change it, no?
Highlighted
I am not quite sure what you are getting at with the question.  With this service you are free to change plans any time and as many times as you wish.  There are no restrictions.  The only thing to be mindful of is that each time a plan is changed immediately, all paid usage is lost.  Most customers future date their changes so that it takes effect at the next renewal.  Having said that most of us are content with whatever plan we have select when joining the service.  We continue to renew on the same plan month after month.
Highlighted
Can we add 200MB ($10) Add-On with any Talk & Text Plan ?
Highlighted
Yes, you can. It will not expire until you fully use up all 200MB of data.
_________________________________________________________________________
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Highlighted
I just switched from Telus. I had been looking at Public Mobile for awhile but felt it was too good to be true. I’m glad I finally went ahead and switched. I’m now saving money on my monthly plan and Public Mobile offers many different plans to meet my needs. I like that I can switch my plan at any time and of course I love the rewards the company offers.
I have been recommending Public Mobile to everyone. I wish I had switched sooner.
Highlighted
Reading alot about making your own plan. I just picked one of the plans offered and wondering if it is better to create my own plan?
Highlighted
@wyldfirez it's worth exploring the build your own plan tool for sure.  You may not find anything that meets your needs/budget better but it's worth a look.
Highlighted
May be its a dumb question, I am sorry about that.
If I activate an account (30 days plan) for instance Dccember 15, what will be my renewal date? January 14 or January 13?
For other operators they have month-month plan so they ignore 31st day of any month, but for Public Mobile its 30 days. Thats mean for above example renewal date will be 13 January or still it will be 14 January?
