03-18-2019 07:40 PM - edited 01-05-2022 03:47 AM
03-18-2019 07:58 PM
@Leon9 Login to your self serve account and pick one of the new plans. That will make you eligible for rewards to reduce the cost: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/General-Reward-Rules/ta-p/164.
Most pioneer customers like you can usually find a similar plan that is slightly less than your current cost. What is your current plan and we can advise you?
03-18-2019 07:46 PM
@Leon9 , not totally sure what you mean by the comment. Generally we rely on the trickle down effect. If cost of service delivery is low, hopefully some of that reflects in the price paid for the service.
03-18-2019 07:46 PM
@Leon9 It's not even 10 yeas since Public Mobile launched or bought out by Telus. According to WikiPedia, they were Founded on March 18, 2010. Then bought out by Telus in 2013. So there is no way you were with them for 10 years.
Anyways, they offer Loyalty discount which is max $5 off. Plus you have the usual AutoPay and Referral discount that you are also eligible for. They are also allowing existing users to come on the new promo plans. So you are getting what all new customers are getting except the exclusive deals like $25 referral bonus or $10 off for 6 months when you activate.
03-18-2019 07:45 PM
