How do I activate the 1G promo ?
Lola23-
7 REPLIES 7
zblackma
@Lola23-  why don't you add a credit card to your account? You can ask @darlicious about the Koho prepaid one if needed. Even if you don't use the credit card to pay and still use vouchers, you get an extra 500 mb of data and $2 off your bill per 30 day cycle.
Starshoot
It's already activated. Your phone will only use the 1GB promo once you run out of your normal data limit, and once it's used up, it will be gone.
Lola23-
Thank you
Dolphin1
Once you use the data under your plan then it will automatically switch to the 1G promo.
hairbag1
@Lola23- wrote:
It is activated already...once you use up your regular plan data, then the promo data takes over until next renewal or until it gets used up.
iliketotalk
@Lola23-
Hello it automatically starts when you run out of data on your plan you do not have to do anything
gblackma
@Lola23- it activates automatically when your plan data is used up until it expires. Stay safe.
