Hi
A_marsh88
how much is 10g of data
9 REPLIES 9
popping
@A_marsh88 wrote:
hoping I can get some more data?
Options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from from self-serve. You get your data back immediately with plan change. Login to your account. Select the Plan and add-ons tab and click on the Change Plan button.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right corner. Moderator wait time is couple hours to 2 days. If your next renewal date is up to 2 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $15 1GB data or $5 200MB data. Expensive option. This is a good option if you need a small amount of data occasionally. Data add-on does not have expiry date. Unused add-on data will be rolled over to next cycle.Please note that there is no refund of the unused days of your current billing cycle if (option 2) you renew your plan early with moderator assistant or (option 1) change plan now.
A_marsh88
  1. Hey sorry 😐 wasn’t sure how this works
As posted in another thread, the $50 gives you 8.5 with autopay and you can buy data add ons for 1GB at $15 each.
@A_marsh88  your answer is on thread below.
https://productioncommunity.publicmobile.ca/t5/Rewards/Hi/m-p/617657#M17969
@computergeek541  another one to merge please. Thanks!
A_marsh88
popping
@A_marsh88
This forum is not a chat line.  You created too many threads with short messages.
You can add posts with short message in a thread.
Welcome to PM.
Triguy
The largest data plan is 8GB with the $50 plan. You can purchase an add-on for 1GB for $15.
Jb456
@A_marsh88  Public Mobile does not offer 10 gig plans.
Highest is $50 for 8.5 gigs (9.5 in Quebec) and includes calling to USA.
You can see all plans at link below
https://www.publicmobile.ca/en/on/plans
If you do decide to join don't forget to use a referral code for a $10 signup bonus.
JoyLuck
This is the highest data plan right now:
