Reply
Re: HELP!!!!!!!!!!!!!!!!!!!!!!!
@JPM1988 wrote:
The problem is I have been patient but I have a empty bank account and funds in paypal that I can not access because of 2 factor authorization so public mobile is double screwing me right now
@JPM1988  Understood but you also need to understand in difficult/challenging cases the moderator will open up a ticket with tech support and is waiting for their response before they can get back to you.
As for PP you should consider adding a backup method of authenticating to avoid situations like this. Having backup options is key.
Re: 84 hours and counting
Does not help when public mobile is also causing banking issues for me (2 factor authorization)
Yeah, Doesn't help me now though
@JPM1988  are  you not able to contact/visit the bank and disable 2fa?  I'm sure there has to be some way to disable it?
its paypal... so no I cannot visit, and I cannot call because I do not have a phone to call them....
@JPM1988  Go to PayPal login and when it asks you to send the text click on the Having trouble link and it will give you a choice to answer your security questions to login. As I said always good have a backup.
Checked only thing it has is "have us call you"
Not that it's a solution but could try Fongo or Google Hangouts Dialer or something in the interim if you need to make an emergency call to paypal
@JPM1988  FYI screenshots of how to login to PP:
