Reply
Highlighted
Got message that 'Talk' is not includede in my package. But I signed up with $25 plan.
Highlighted
Re: Got message that 'Talk' is not includede in my package. But I signed up with $25 plan.
Try dial 1+area code + phone number
Highlighted
@standart  Log into your account and doublecheck what plan features show in your account. Try rebooting your phone. Did you just renew your plan?
Highlighted
@standart Double check your self-service account. If it says 25$ plan, then just restart your phone. In most cases, it helps.
Highlighted
@standart  try adding $1 to your self service / my account to kickstart it. If this , or the other  suggestions fail. Contact a moderator and explain your situation . Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon.  Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
Highlighted
Assuming that there isn't a misdialed phone number, that wouldn't normaly fix this.  Dialing the 1 before the area code only eliminates the "long distance charges may apply" message, after which the calls would be completed anyway.
"Talk not included" means that there is no active calling plan or in some cases, that an invalid phone number is being dialed.
