Failed to add US Roaming
ksckwong
Hello
I travelled to US on Nov 27 for a week and added the basic talk US Roaming on the same day.
My service provider changed to AT&T, however I was unable to make any calls during my stay in the US. Is there any way I can get a refund?
Secondly, I am not sure how the payment works and it charged me with $2.23 on my credit card. Does it redeemed from my earned credits?
Hope someone can shed some light on how to get a refund on the "add on".
Thanks.
19 REPLIES 19
mo160319
Well noted.
I actually did all the steps, and the funds were debited from my account. I don't know what happened but I wrote to the moderators to see what can be done about it. I hope there is a solution.
Thanks a lot for the guidance - I appreciate it!
@mo160319, if you’re back in Canada now, you should just leave the money as available funds, as you haven’t applied the add on fully.
if you’re still in the US, redo the same steps you did to add the money, to now add the addons.
@mo160319
end a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
mo160319
thanks, how do I reach the moderators? I am pretty new. kindly guide me, contacts or links. thanks!
popping
@mo160319 wrote:
 Hello there:
I need your help.
I was in the US, signed up for text roaming, and I was unable to text anyone in the US. Though the amount was debited from my account, the service was not accessible.
I am a new user, and I will appreciate any efforts to guide me through the process to claim a refund.
Thank you, and I look forward to your guidance.
Buying add-on is a 2 steps process.  You probably did the first step.  You account should have $8 available fund.  If yes, you completed the first step.  Now, go to the same screen again to activate the US roaming text plan.
@mo160319
For account related issues, you will need to contact moderator.  Expect 1-2 day wait.  Provide a detailed message.  Generally speaking, since Public mobile is prepaid, there is no refunds, but the moderators are usually accomondating with these type of situations.  No guarantees though....
send a private message through the following link :
mo160319
 Hello there:
I need your help.
rkreddyb4u
How to confirm purchase during low blance scenario.
Step-1 - Select the required addons
Step-2 - System will prompt "Top up to Purchase addons"
Step-3 - Complete the topup
Step-4 - Click Go Back
Step-5 - Now click Purchase Addons
Hope this helps!
Thank you
BlueTruck
I ran into a similar issue when trying to purchase the LD add-on.
I had a $6 in Available Funds in my account initially, so I selected the 400 min add-on and clicked 'Buy Add-Ons'. After processing the transaction $9 I now had $15 in available funds, but the LD was not added to my account - I had to select it again before it showed up in my Current Add-Ons, and used up whatever was in my Available Funds.
ksckwong
Unfortunately I don't remember; but what you saying is making sense for that $2 difference. So my $2 is sitting in some PM account?
I believe I also read something similar to what you described.
For future reference, how do I confirm my purchases?
rkreddyb4u
Ok by any chance do you rememeber what was the available funds amonut prior to US Roaming purchase attempt ?
lets say the available funds = $8
Now you tried purchasing US Roaming Addon = $10
Selfserve will prompt topup $2+tax to purchase the selected US Roaming Addon
Topup successful
However you will have to go back and confirm the purchase; if not confirmed, that means US Roaming Addon is not added to your acct
ksckwong
Thanks
I checked my Rewards tab on my profile
that $8 was posted on my account as "Available funds in your account", which means I prepaid another $8 for the upcoming payment in February 2017. So the add on was never added.
I just need to check with the MODs with the mysterious $2.23 charge now.
rkreddyb4u
ok that explains account was not charged for US Roaming addons. It could be the case where purchase was not completed or purchase failed etc.
ksckwong
No debit was found.
@ksckwong Not your fault. Seems getting an add-on sometimes requires two steps:
1. add money, log out
2. login and pick the add-on, click activate now
rkreddyb4u
and do you see the debits for the US roaming addons that you purchased ?
ksckwong
No sure if you can get any info out of this.
This was posted on my credit (payment) side, which reconcile as my visa card payment.
Nov 26, 2016Credit/Visa Debit TopUp-Réapprov crédit/Visa Débit$2.00
My bad on not reading the details while making purchase for the add on, thought it would be straight forward.
rkreddyb4u
Hi,
Login to selfserve and goto payments and then Transaction Hisotry tab to see if there are any records for US Roaming addons purchase. This should clarify if any earned credits were taken into account during purchasing US Roaming addons.
Hope this helps
Thanks.
NDesai
Only way is to contact them. But it might take some time to get a reply.
Send a private message to one of the mod.
