Reply
Extra minutes
@Moderator_Team
i have the $10 plan and I used up my 50 minutes. I looked for an add-on for some extra minutes, but could not find. Is this available? Or do I just have to wait till the plan refills?
Re: Extra minutes
Yes you can buy extra minutes yourself. You do not need the moderators.
Login to you account.  In the bottom half of the overview page is Purchase add ons. You want to get either 200mins for $8 or 400mins for $15. These minutes do not expire until they are used up. Do NOT buy the US Roaming addon minutes.
Re: Extra minutes
You can wait until your current plan renews if you want or you can restart a new plan immediately. If you need more talk, once you've renewed your plan you can get an add-on for 400 mnutes of international long distance talk for $15. Alternatively, you can get an add-on for 200 US and Canada minutes for $8. These minutes don't expire until you've used them up...long as you have an active account. Good deal, huh !
Re: Extra minutes
Hi @Jerelo22!
 As @ShawnC13 has corrected my previous comment, you can choose to either buy a talk add-on or renew early.  The talk add-on will not expire and will kick in when neede in future as well.
Best thing to do would be to renew your plan early.  Sign into selfserve and do it and you will have access immediately.  Let us know if you need help navigating the selfserve portal.
You can not use the long distance add-ons without a base talk plan.  In your case, since you have run out of talk minutes, the add-on will not restore calling feature.
Re: Extra minutes
@imm1304, you can use the long distance minutes when you have used up all your plan minutes with this limited minute plan.
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click here to private message a Moderator *
Re: Extra minutes
@imm1304 are you sure on both counts?
I am 99.9 %, sure you can add 200 or 400 long distance minutes to the 10$ plan.
And I think only mods can do early renewals unless that has changed recently.
Re: Extra minutes
Hey @mimmo,
Shawn confirmed that you can use the add-on when running out of minutes on the $10 plan.
Early renewal I thought can be done for current in-market plans.  For those of us on grandfathered plans can not do it as there is no option to keep that plan from our end.
Re: Extra minutes
@imm1304 hopefully someone can confirm either way.  I know they now allow changing plans on expired accounts. But from what I remember immideate plan changes to the same plan was still not possible.
I have no experience either way though.
Re: Extra minutes
If my minutes run out can I wait until my monthly renewal starts.
Re: Extra minutes
That's how it works.
Or you can buy the long distance add-ons.
Or you can change to an unlimited plan.
Or you can ask the moderators to do an early renewal for you.
