07-14-2019 07:48 PM - edited 01-05-2022 05:52 AM
Hi there!
I am new to public mobile, and have started a plan, and the only issue i have encountered is that when i go to put the number for my Voucher in, it is telling me that it is invalid.
I bought the voucher around 36 hours ago, and even after 24 hours it is not working.
I would really love to figure this out as i spent $50 on vouchers.
Thank you
07-14-2019 08:00 PM
I'm sure you'll want to keep trying to enter the vouchers you have, using the suggestions offered here, before buying more vouchers.
07-14-2019 07:55 PM
If calling 611 and the voucher is still not accepted, take a picture of it and send it to the moderators. Should this be the route you take you will probably need to buy a voucher to top up while they investigate and get back to you, as this can take several days.
07-14-2019 07:52 PM - edited 07-14-2019 07:53 PM
@nadiab13 hi have you tried *611 on your phone?
07-14-2019 07:52 PM
Make sure you are using th pin on the reciept. Enter in using *611 on your phone.
07-14-2019 07:51 PM
