05-17-2019 02:03 PM - edited 01-05-2022 04:59 AM
My daughter is away with her phone in the US right now. All her data is turned off in her settings.
I just purchased a one-time add-on for US data. What instructions should I send her to enable the use of the data in the settings? She has an iPhone 6.
05-17-2019 02:17 PM
@geopublic many thanks!
05-17-2019 02:15 PM
@Von wrote:Thank you @geopublic .
Does she need to toggle her cellula data on first so she can access the roaming option?
@Von Sorry, yes she does.
05-17-2019 02:12 PM
05-17-2019 02:07 PM - edited 05-17-2019 02:14 PM
@Von wrote:My daughter is away with her phone in the US right now. All her data is turned off in her settings.
@VonHow to enable roaming on an iPhone:
Select Settings > Cellular > move ‘Data Roaming’ to the ‘ON’ position.
Also confirm that Cellular Data is Enabled. Open the Settings app and tap on "Cellular".
Toggle the switch next to "Cellular Data" so that it’s in the ON position.
05-17-2019 02:07 PM
once you have activated it on the acount she should recieve a notification and then be able to use it:)
