Reply
Highlighted
Re: Dropped Calls
Before you give up on PM...click on the ? in lower right side of screen to start process of moderator assistance. They may have a few ideas to help. Type "contact a human"...then clcik "Contact Moderators"...follow guide.
Highlighted
Re: Dropped Calls
This sounds like a temporary solution to me.
Contact mod > They "fix it" for X amount of time > Problem persists > Rinse and repeat...
Highlighted
Re: Dropped Calls
I am curious to know whether anyone has had any resolution to their dropped calls.  I have recently been experiencing the same thing.  For several weeks I was calling and receiving calls from a new long distance number with conversations lasting from a few minutes to a few hours.  Then last week the calls started to drop.  Sometimes as the call was ringing it would drop.  Other times it would be after talking a few minutes.  It seems as though this specific number is not allowed!
Highlighted
Re: Dropped Calls
Hi,
Today I get to say that while on call the call dropped. I'm not impressed at all. And even though I'm certain my complaint will fall on deaf ears I shall say that my call dropped after 30 minutes of being on the phone (a rather important call too) and I'm putting this here as a means to say that I lodged a complaint so no one can say otherwise.
Highlighted
Re: Dropped Calls
I have been complaining about this since last year and there has been no solution to date. If you pay close attention, not only is it dropped calls, but many calls do not even go through and will be directed straight to your voicemail.
2 phones in my family (both in BC), and experience this problem DAILY.
Highlighted
Re: Dropped Calls
@sm2016 question:  what is the phone brand and model of both affected phones?  Please be as specific as possible on the model numbers.
Highlighted
Re: Dropped Calls
@srlawren
iPhone 7 model: A1778
iPhone 8 model: A1905
I have the same problem on both models indicated above
Highlighted
Re: Dropped Calls
I experienced something I have never experienced before with my phone. I'm not sure if it is the fault of the phone, the service or both.
I called a customer hotline and the phone did not ring, but the call counter started as if someone picked up. I spoke and I heard myself. Confused, I spoke again and continued to hear myself. I hung up and called back and then it went through.
Highlighted
Re: Dropped Calls
@sm2016 wrote:
@srlawren
@sm2016 interesitng.  I'm going to tag @CalgaryBen to see if he has any ideas.  (I'm an Android guy personally.)  EDIT: also tagging @sheytoon to see if he can think of anything network-related that might be the cause.
Highlighted
Re: Dropped Calls
If the drops are happening in only a specific location, it might be a coverage issue with a site.
If it's happening everywhere, it could be the provisioning or other issues in the core network.
