Does data carrie over to the next month?
Noko
Hey guys, just wondering if I don't use my data this month will it just be added  to next month?
7 REPLIES 7
Reynolds10
Hi there!
Unfortunately un-used data in a given month does not roll over to the following month.
Stay safe!
RosieR
Hi @Noko so data included in your plan does not carry over.  I hope that is not a problem for you.  I don't use a lot of data (unless I forget to connect to WIFI lol) so I'm ok.
Welcome to Public Mobile and the Community!  Cheers!
brettster99
The data the comes with the plan does not rollover. Add on data on the other hand does rollover until it is 100% used up
Halo66
Only add ons carry over with no expiry date as for the planned data it does not carry over but add-ons data is very reasonably priced so if you run out pick up an add-on that will carry over until you use it and finish it
maggamoka
Add-on data as a backup is a great idea, especially if you have a small data plan. It's not expensive, and you're sure you won't be cut in a difficult situation, like being cut out in the middle of a phone call. I definitely recommend it.
geopublic
@Noko  plan data does not carry over. Add-on data stays on your account until all used up. So purchase add-on data as a backup measure of you need to.
gblackma
No @Noko plan data resets each 30 day cycle and doesn't carry over. Welcome to PM.  Stay safe.
