Reply
Data
Hi all, I'm a new member and can't seem to get my public mobile data to work. I can get wifi from my home server st home but when I tried to use my data when I was away from home I got nothing. Airplane mode is off. It says I have used 0 data out of my available
1 gb.
Re: Data
@Silvaggios
Make sure in your phone's settings that your cellular data is turned on.
Check the apn settings on your phone are:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
More info for particular devices:
https://apn-canada.gishan.net/en/apn/public-mobile
Re: Data
1 gb.
@Silvaggios You need to have there correct APN entry. What is the make and model of your phone?
Re: Data
My phone is an Asus zenphone go zb551kl
Re: Data
@Silvaggios  Other customers with Asus Zenfone had to add the APN manually. If your Android version is 8.1 you might not be able to add the APN and the only way to add it is to use a Freedom mobile sim or a roam.com sim. For other versions of Android you should be able to add it manually.
Re: Data
Do I need to type all of the above in?
Re: Data
@Silvaggios
Yes, you will need to enter everything manually.  Hopefully, it will let you enter manually.
Re: Data
Thanks it worked
Re: Data
i also tried to do this in my setting and still iam getting no data on my phone, i have a google pixel xl phone,how can i get my data to work???? i paid extra for this......!
Re: Data
@sonalisoni1796  A Pixel XL should work with data on PM without any issues. Make sure data is on, mobile network is connected to Public Mobile and the APN is set to sp.mb.com.
