09-15-2019 09:41 AM - edited 01-05-2022 07:06 AM
09-16-2019 01:18 AM
@mimmo wrote:Just ask mods for an early renewal or do an immediate plan change to a different plan. You could for example switch to 10 plan then back to the 8gb plan would cost less than 3 @,$30 ddata addons.
Or you could check out chatr and lucky which offer unlimited data at much reduced speeds after plan data is used.
Changing plans mid cycle would have much more cost effective. You paid $135 assuming ($50-$5rewards+3×$30) is 11.5gb @mimmo suggested ($45+$10+$50=$105) is 17gb or you could ($45+$40=$85) is13.5gb Either of these would have increased your data at lower price. $60 to get 5.5gb more than your add ons and $40 more to get 2gb more than your add ons. Or$60 /8.5gb and $40/5gb the latter enabling you to change again to the $50 8.5gb plan when you ran out of data. If you have a dual SIM phone you could activate another account and have it bridge your data between renewal date and let the new account suspend once a cycle to save money. Activate mid cycle to your original account. As you run out of data on your #1 acct switch to #2 data and use up into your #1 new cycle til data exhausted. Then allow #2 to suspend til you almost run out of data again on #1. On average paying for 3 plans every 2 months. ($45+$50+$45=$140) 25 gb of data for 2 months or 12.5gb per month for $70 (4gb /$25) rather than $30/1gb add on cost.
09-15-2019 09:48 AM - edited 09-15-2019 09:50 AM
